Hàng Không Mẫu Hạm Kuznetsov
Chủ đề thuộc danh mục 'BST Mô hình tỉ lệ thật' được đăng bởi youngboss1vn, 12/9/09.
    * HÀNG KHÔNG MẪU HẠM KUZNETSOV
    (USSR Admiral Kuznetsov aicraft carier)
    Country Of Origin: Russia & States Designation: Aircraft Carrier Class: KUZNETSOV (Type 1143.5) (CV) In Service: 1 In Development: 1
    Pennant Number
    Ships Name
    ADMIRAL KUZNETSOV (Ex-Tbilisi, Ex-Leonid Brezhnev)
    VARYAG (Ex-Riga)
    DIMENSIONS
    Displacement: 67,500.0 (Tons) (Fully Loaded) Length: 280.0 (Metres) Beam: 37.0 (Metres) Draught: 10.5 (Metres) Flight Deck: 304.5 (Length Metres) Flight Deck: 70.0 (Width Metres) Speed: 30.0 (Knots) Range: Unknown (Miles)
    DETECTION SYSTEMS
    Air Search: Sky Watch, 3D
    Air & Surface: Top Plate
    Surface: 2 Strut Pair
    Navigation: 3 Palm Frond
    Fire Control: 4 Cross Sword
    Aircraft Control: Fly Trap B
    Sonar System:
    Horse Jaw (Hull mounted)
    ARMAMENT
    Missiles: SSM - 12 SS-N-19 Shipwreck launchers (Flush mounted)
    SAM - 4 SA-N-9 Sextuple vertical launchers SAM/Guns: 8 CADS-N-1; each with twin 30 mm Gatling
    combined with 8 SA-N-1 1 and Hot Flash / Hot Spot fire
    control radar/optronic director Guns: 6-30 mm /65 AK 630 (6 barrels per mount) Decoys: Chaff launching system
    AIRCRAFT
    Fixed Wing: 20 Su-27K Flanker D
    4 Su-25 UTG Frogfoot Helicopters: 15 Ka-27 Helix
    3 Ka-29 Helix AEW
    Mô hình TÀU SÂN BAY KUZNETSOV
    Hình thật TÀU SÂN BAY KUZNETSOV
    và trực thăng Ka - 27
    máy bay chiến đấu Yak - 141
    Máy bay chiến đấu Su - 27k
    Máy bay chiến đấu Mig - 29k
    Máy bay trực thăng Ka - 27
    The Kuznetsov Class heavy aircraft carrying cruiser, also known as Project 1143.5 or Orel Class, was constructed at Nikolayev South Shipyard on the Black Sea in the Ukraine. The Admiral Kuznetsov, was launched in 1985. A second of class vessel, the Varyag, was launched in 1988 but was never commissioned. Admiral Kuznetsov is the only aircraft carrier in the Russian Navy. The hull design is based on the earlier Admiral Gorshkov, launched in 1982, but it is larger with a full load displacement, 58,500 tons as compared to 40,400 tons. Admiral Gorshkov has not been operational since 1988 and is being sold to India.
    The Admiral Kuznetsov supports strategic missile carrying submarines, surface ships and maritime missile-carrying aircraft of the Russian fleet.
    AIRCRAFT
    The flight deck area is 14,700 square m and aircraft take-off is assisted by a bow ski- jump angled at 12 degrees. The flight deck is equipped with arrester wires. Two starboard lifts carry the aircraft from the hangar to the flight deck.
    The ship has the capacity to support 16 Yakovlev Yak-41M (NATO code name Freestyle), 12 Sukhoi Su-27K (NATO codename Flanker) fixed wing aircraft and a range of helicopters including 4 Kamov Ka-27-LD (NATO codename Helix), 18 Kamov Ka-27 PLO, and 2 Ka-27-S.
    MISSILES
    The ship has a Granit anti-ship missile system equipped with 12 surface to surface missile launchers. The Granit missile (NATO codename SS-N-19 Shipwreck) is reported to have a range greater than 400 km and is capable of carrying either a nuclear or conventional warhead.
    The Klinok air defence missile system, with 24 vertical launchers and 192 missiles, defends the ship against anti-ship missiles, aircraft and surface ships. The system has a multi-channel electronically steered phased array radar and can achieve a firing rate of 1 missile every 3 seconds. Four targets can be engaged simultaneously in a 60 x 60 degree sector. Range of the system is 12 to 15 km.
    The Kashstan Air Defence Gun/Missile System, supplied by the Instrument Design Bureau and Tulamashzavod JSC in Tula, provides defence against precision weapons including anti-ship and anti-radar missiles, aircraft and small sea targets. Eight systems are fitted, combining missile launcher, 30 mm twin gun and radar/optronic director. The range of the laser beam-riding missiles is from 1.5 to 8 km. The gun can fire up to 1,000 rounds per minute in the range 0.5 to 1.5 km. Six AK630 AD 30 mm air defence guns are also fitted.
    ANTI-SUBMARINE WARFARE
    The ship is equipped with an Udav-1 anti-submarine system with 60 anti-submarine rockets. Udav-1, supplied by the Splav Research and Production Association in Moscow, protects surface ships by diverting and destroying incoming torpedoes. The system also provides defence against submarines and saboteur systems such as underwater vehicles. The system has 10 barrels and is capable of firing 111SG depth charge projectiles, 111SZ mine laying projectiles and 111SO diverting projectiles. The range of the system is up to 3,000 m and the submarine engagement depth is to 600 m.
    SENSORS
    The ship's radars include a D/E band air and surface target acquisition radar, an F-band surface search radar, G/H band flight control radar, I-band navigation radar, and four K-band fire control radars for the Kashstan Air Defence Gun/Missile System.
    The ship's hull mounted search and attack sonar, operating in the medium and low frequency bands, is capable of detecting torpedoes and submarines. The anti-submarine warfare aircraft are equipped with surface search radar, dipping sonar, sonobuoys and magnetic anomaly detectors.
    PROPULSION
    The ship is conventionally powered and has eight boilers and four steam turbines each producing 50,000 horsepower, driving four shafts with fixed pitch propellers. The maximum speed is 29 knots, and the range at maximum speed is 3,800 miles. The ship provides a maximum range of 8,500 miles at a speed of 18 knots.
